Feature Product: Motor Master Powersports Complete Axle
Sept. 26, 2017
Motor Master Powersports Complete Axle Assemblies are built to meet or exceed OEM quality. MMPS uses fully assembled outboard and inboard joints installed on a 300m alloy axle bar using the MMPS Dura-Boot for maximum protection against all conditions! Available for Polaris XP1000 and XP Turbo.
REAR XP1000/XP Turbo Technical Details - CLICK HERE TO PURCHASE
- 30% Stronger than Stock
- 300m alloy axle bar
- Includes Dura-Boot for maximum protection against all conditions
- outboard cv joint seal diameter: 1.180
- outboard cv joint spline diameter: 1.120
- outboard cv joint thread size: 18x1.5mm
- number of outboard cv housing splines: 26
- number of inboard cv housing splines: 28
- inboard cv joint spline diameter: 1.200
- inboard cv joint seal diameter: none
- outboard cv joint seal diameter:1.180
- outboard cv joint spline diameter:1.120
- outboard cv joint thread size:18x1.5mm
- number of outboard cv housing splines:26
- number of inboard cv housing splines:22
