Cagewrx Vision Canopies Polaris RZR Pro R Walkaround
Aug. 2, 2023
We are going to walk you around this brand-new Cagewrx Vision Canopies Pro R with off-road champions Mike Cafro and show you all the badass accessories from Cagewrx.
First thing first, at the speeds these UTV’s are now going you need to get a proper aftermarket roll cage And no one makes a better cage than Cagewrx. Keep yourself and everybody in your car safe.
With the speeds that these UTV’s can go, you need a proper aftermarket roll cage, and no one makes a better cage than Cagewrx.
https://www.youtube.com/watch?v=umrCK-XVgcw
Roll Cage:
This Pro R features the "Baja Spec" fully assembled Roll Cage with a Powder Coated roof. All of the tubing is Laser Cut and CNC Mandrel Bent for a precise fit. The main tubes on the roll cage have a .120" wall thickness and 1.75" overall diameter so you know it's solid.
Front Bumper with optional bolt-on Outer Light Tabs:
Up at the front is the The Cagewrx front bumper, which comes with a bracket to mount a 10" light bar, or 2 pod lights. This bumper comes with optional outer tabs to bolt on to add bigger pods.
Cagewrx Front Grille:
Sitting just behind the bumper is a new release, the new Cagewrx Pro R custom front Grill. Made from a Custom Steel mesh for strength and protection this Grille also gives you plenty of airflow for cooling.
Full Glass Windshield:
Sitting up above the hood is the Cagewrx Glass windshield, which is DOT laminated glass and is a complete bolt-on with our roll cage and roof perfect for riding with an open-face helmet.
Aluminum Doors:
Plastic doors suck. Upgrade to these beautifully fitting Cagewrx Custom doors.
On the sides, we have these aluminum Cagewrx custom doors. On top of being stronger, these doors have a raised height for better protection, with a new door latch to make it easier to open.
On top of being stronger, these doors have a raised height for better protection, and a relocated door latch assembly to make them easier to open.
Quick Release Seat Mounts for Sparco Seats:
Seat mounts are the only QUICK RELEASE seat mount on the market for Sparco seats and you can also still use the slider
Inside, we have these quick release seat mounts for Sparco seats. These are the only quick release mounts for Sparco seats on the market. And, these mounts still allow you to use the slider.
Rear Wing with cutout for Baja Designs 30" RTL Chase Light:
Moving to the back, is the Cagewrx rear wing. This wing wraps around your rear chase light, so it doesn’t stick out, and flows with the design of the car, keeping that race car look.
Spare Tire Carrier:
Finally, we have the The Spare Tire Carrier on the rear. This will fit up to a 35" tire no problem, and fits the factory Polaris Lock and Ride Boxes underneath.
The Spare Tire Carrier has 2 extra tubes coming off the sides in the rear that are not standard on our tire carriers. Those were custom added. Just a heads up in case you touch on the carrier.
You can pick up all of these accessories at your local Powersports dealer or order direct at cagewrx.com
