2021 Kawasaki Mule Pro DXT and Mule PRO DX FE
The Kawasaki MULE PRO™ series features the fastest and most powerful MULE™ side x sides ever built with both single and two-row models available. They are Trusted, Tried and True to be the right tool for anyone who needs to transport passengers or cargo on the jobsite or on the trail.
The MULE PRO-MX™ side x side brings a mid-size option to the MULE™ PRO Series. A comfortable fit for two passengers, the muscle to cover more ground in less time, and the capability to get out for some fun when the work is done.
Powered by a 695cc three-cylinder fuel injected DFI® gasoline engine that delivers 42.7lb-ft of torque. Power from the engine is passed through a precisely tuned Continuously Variable Transmission (CVT) with an electronically selectable 2WD/4WD system and a dual-mode locking rear differential, giving the driver control in a variety of conditions.
The diesel-powered MULE PRO-DX™ and MULE PRO-DXT™ models also return for 2021 to the diverse line of side x sides. The MULE PRO diesel-powered series is perfect for any ranch, jobsite, farm or fleet. Designed to work hard, the three-passenger MULE PRO-DX line comes equipped with the largest cargo bed in its class, while the MULE PRO-DXT features a class-exclusive three- to six-passenger Trans Cab™ system that quickly converts the vehicle from single-row to double-row seating. To top it off, all Kawasaki MULE side x sides are confidently backed by the Kawasaki STRONG 3-Year Limited Warranty.
Each MULE PRO side x side is built with a tough chassis that provides a smooth ride through the use of independent suspension front and rear. The suspension provides a generous wheel travel and excellent ground clearance to tackle any obstacle or task.
KAWASAKI MULE PRO-MX™EPS
Color: Timberline Green, Bright White
MSRP: $11,999
Availability: June 2020
KAWASAKI MULE PRO-MX™EPS LE
Color: Firecracker Red, Super Black
MSRP: $12,599
KAWASAKI MULE PRO-MX™EPS Camo
Color: Camouflage True Timber® HTC Green
MSRP: $12,699
KAWASAKI MULE PRO-DX™EPS
MSRP: $14,199
Availability: Now
KAWASAKI MULE PRO-DXT™
Color: Super Black
MSRP: $14,399
Availability: Now
KAWASAKI MULE PRO-DXT™EPS
MSRP: $15,199
Availability: Now
