SSV system
megadesertdiesel
Jan 25, 2009
1,838
73
Mesa, AZ
i have their complete system with both amps. i added a 1.5 capacitor for the bass and only use a bluetop optima under the hood. i also run an alternator to power everything at once.
dont forget to go baller status with video screens and seat heaters.
controled force
1004CC Turbo Tax - UTVUnderground Approved
Apr 8, 2009
209
7
Sac.Ca
I like the windscreen, do you have dimensions of it and where you got it?
Rog
I bought it Sand Mountain NV. from a vendor,it measures 46 by 26& a half...the the only thing it says is....CLASSIC QUAD GEAR EXTREME..hope that helps.
SSVworks
12
5
www.ssvworks.com
Nice install. Great pics. Cool amp mount under the seat.
We've had good luck with the 925 battery replacement only BUT... we didn't have 5-6 Hid's at the same time. 2nd batterys always nice,but you have to remember to charge it at camp as the stator can't kep up with 2
-T
Reactions: 1 person
catrep
12
I have a 2008 Rhino with aux PC925 kit and isolator with complete SSV system and amp, which is the best way to hook up my system do i need to upgrade anything on my Rhino so i my aux battery is staying charge. any advise or pictures to hook my system
G.T.
Jan 15, 2010
180
5
41
Gilroy, CA
The SSV instructions that came with the kit for my Teryx were pretty straightforward. I'm running the PC925 battery as well and have never had a problem. I just don't run my HID's and stereo at the same time. Installing a voltmeter is also a good idea to keep an eye on your battery. I try to charge my battery before going out just so I know its topped off. As others have stated, the stator is insufficient to keep that Odyssey charged when running the stereo so it may be a good idea to install an alternator kit. I routed the plug in for the ipod to the glove compartment and have a switch on the dash for the remote turn on lead for the amp. If you have any installation specific questions let me know...
G.T.
Jan 15, 2010
180
5
41
Gilroy, CA
BTW...Black Rhino Performance has a nice gauge mounting setup that I run in my Teryx to house the switch and voltmeter I mentioned earlier. (just thought I'd throw that in after seeing the last post)
