just got done with changing the color of my rear suspension
Discussion in 'UTV Paint & Graphics' started by megadesertdiesel, Aug 6, 2013.
  1. megadesertdiesel
    megadesertdiesel Well-Known Member
    Jan 25, 2009
    Mesa, AZ
    didnt turn out too bad. I bead blasted and painted the arms and springs then made my own aluminum exhaust heat shields. I also cut some large holes in them for access to the shock adjusters.
    the passenger rear hub is off to replace a bent rotor. Its been ordered for 4 weeks now. And those damn hubs are on with blue loctite, i had to tap it off the whole way. It will go back on with a little neverseize for easier removal next time.
    next up is the front suspension.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Chenille
    Chenille New Member
    Aug 7, 2013
    Seems like you have done a pretty good job with your rear suspension and I did the same and end up with replacing the suspension.
  3. megadesertdiesel
    Jan 25, 2009
    Mesa, AZ
    removed the front suspension this weekend and bead blasted all of it. Then hit it with some white paint. Also did the outer rings of my led headlights. I also made some inner splash guards out of aluminum with some mesh for more airflow.
    i still need to paint my front bumper and install it.
    [​IMG]
    [​IMG]
  4. sand shark
    sand shark Well-Known Member
    Mar 30, 2009
    West Hills, CA
    Looks good! Are you going to paint or change your plastics?
  5. desertwheeler
    desertwheeler Extra Crispy
    Oct 25, 2011
    Barstow
    Very nice!
  6. megadesertdiesel
    Jan 25, 2009
    Mesa, AZ
    I am going to order the 2014 white plastics and wrap the black panels white. Then powdercoat the wheels red.
  7. sand shark
    Mar 30, 2009
    West Hills, CA
    that will look sweet
Share This Page
