Yamaha Front Axle popping out
ParaPros Racing
parapros racing
Jun 27, 2009
96
sun city CA
I have the SDR long travel and my front right cv pops out of my front diff about 1/4 inch or so any have this happen ?
what can I do to fix it ? Brad
brevndeb
Your Mom
May 5, 2010
911
5
47
Beaumont CA-B-Town
Check the c clip at the end of the axle it could be worn out from when the kit was installed or it could have popped off. Install a new clip and see what happens.
soazcat
35
Willcox Az
while you have the axle out make sure the CVs are clocked correctly . most likely its the C clip . but alot of people dont think about the clocking of the CVs and under extreme angle it puts them in a bind and can cause them to pop out.
good luck
AZCourt
Feb 11, 2009
525
11
Make sure the star in the cv is not backwards and check the location of the diff. The front diff mounts are really weak.
ParaPros Racing
parapros racing
Jun 27, 2009
96
sun city CA
what its doing is when its all together I go to tighten the axle nut
it pulls the cv right out the diff almost as if the axle is a little to short I checked the axles and they are right so just not sure
thanks for the help
Brad
tatum
Feb 10, 2009
1,450
198
arizona
I agree with Court,make sure your frt diff has not moved because the mounts are weak.Also make sure the inner cv is plunging all they way in and out otherwise your axle is to short.
AZCourt
Feb 11, 2009
525
11
Don't forget to check the star. It's about 1/4" off if it's in backwards.
