FEATURE PRODUCT: MOTOR MASTER AXLES
UTVUnderground Garage Feature Product: MOTOR MASTER AXLES
UTV Complete Axles
Motor Master Powersports Complete Axle Assemblies are built to meet or exceed OEM quality. We use fully assembled outboard and inboard joints installed on a high strength axle bar using the MMPS Dura-Boot for maximum protection against all conditions!
Don’t mess with the rest… Motor Master provides the most extensive axle coverage in the aftermarket offering more than 190 Complete Axles for Arctic Cat, Honda, Kawasaki, Polaris, Yamaha and more!
With our accurate cataloging and technical experts always on hand to answer your questions or concerns you can buy with confidence, knowing that you’re going to get the axle you need to get you on the trail in a hurry. MMPS carries a huge inventory of all the components required to build all the axle shafts we offer to assure that when you need it…. We will have it!
You can learn more about these axles, get pricing and order direct by CLICKING HERE
Motor Master Axles come complete from the UTVUnderground Garage and are available for front and rear RZR applications
UTV Complete Axles
- Technical Details
- 30% Stronger than Stock
- 300m alloy axle bar
- Includes Dura-Boot for maximum protection against all conditions
- outboard cv joint seal diameter:1.180
- outboard cv joint spline diameter:1.120outboard cv joint thread size:18×1.5mm
- number of outboard cv housing splines:26
- inboard cv joint stub height:1 1/2
- number of inboard cv housing splines:22
- inboard cv joint spline diameter:0.950
- inboard cv joint seal diameter:none
- overall compressed length:29 7/8
