Of course you do, but that's not what we are talking about here.
If you're like us and run a lot of desert and mountain trails as well as the dunes. When you get up to speed it's amazing how much stuff flies off of the front tires and shoot's right back to the rear lower fender, trailing arms, radius rod, axles etc.. It really puts a beating on those components, chipping and sand blasting them. Those nicks and dings not only ruin the finish but are doing untold damage long term.
Our first thought was to make a front skirt, but you would have to make it too long and low to be effective. Also, didn't want anything on the trailing arm, because we felt it would get hung up when rock crawling and dune transitions.
So we came up with our Fender Skirts that not only protects the rear lower fender, but more importantly the rear components.
You will feel the difference right away!
These are not a sheet product or rubber. They are a cast Polyurethane product that we mold in house. This allows us to choose a material that is hard enough to maintain a thin cross section, holds it's shape and is tough enough to take a beating but flexible enough to get out of the way when it needs to.
Simple to install!
Our Skirts come with all of the hardware and are pre-punched for a super easy installation. Simply remove the two (2) plastic body pins from the lower inside mounts on the rear fender, slide the Skirt in place and install the provided hardware. Once you have those installed, line the skirt up on the fender and drill three (3) 1/4" holes through the fender at the three (3) locations on the Skirt. Install the remaining hardware tighten everything up and your done.
So if you looking to eliminate that empty bottle, machine gun rata-ta-tat-tat You're hearing running down your favorite trail, our Fender Skirts will do the job!
If you have any questions feel free to give us a call at 760-955-1409
Enjoy the ride!!!
Simple to install!
Enjoy the ride!!!
