Yamaha Calling all old rhino mechanics
jlbierig450r
Mar 26, 2010
102
Oklahoma
Have a few questions for the guys that have had the exhaust studs break off in the head. I have a real mess on my hands now and probably have to remove the head to work on these bolts. (yea tried to drill it out while still on the engine) DOH
Has anyone heli coiled these studs? How deep can you drill don't want to get into the water jacket. Can you do this on the machine? Thanks for the help guys.
onerich
Jan 29, 2011
3,301
20
Elmonte, SOCAL
I have heard heat them up(maybe with a torch) if you need to take them out , but I think your passed that Good luck
c&c rhino
Jan 18, 2009
351
11
lake elsinore, ca
we were always able to use an ez out with the head still attached. lots of times till i just started snugging them tight and using a second nut to lock in place. and a chain from the valve cover to the frame to limit engine flex.
philofab
Golf Cart Destroyer
Sep 27, 2011
13
Laughlin Adjecant
In the future I've always had good lust welding a little bit of stainless to the stud (if it's not to deep) and work it out while still warm. I normally TIG it but I have had Mig work too.
The aluminum expands as it sucks the heat out of steel. It's gotten me out of some jams.
jlbierig450r
Mar 26, 2010
102
Oklahoma
Thanks for the update guys. I ended up putting a helicoil on the stud and seems to be holding so far. I tried welding a nut to the broke off stud with no luck. It was broke off to deep. So had a good pilot for the bit on the helicoil. Worked out and seems to be working fine. Thanks.
