Yamaha brake fade
tatum
Feb 10, 2009
1,450
198
arizona
Has anybody tried using Dot 5 silicone brake fluid in there UTVs.I am having trouble with brake fade on the faster short tracks with hard braking.
AZCourt
Feb 11, 2009
525
11
Yes, I did it and have had no problems since. You need to get all of the old stuff out, I flushed at least 2 quarts of dot 5 thru. Do you have outboard brakes on the back? that helped a lot also, i put brembos back there.
tatum
Feb 10, 2009
1,450
198
arizona
I have the stock single brake with a oversize rotor that definetly made a big improvement.Did you just mod your stock uprights for the brembos ore buy later model ones.I have thought about this mod but have also seen alot of issues with rocks in the wheels.
Hounslow
El Jefe Numero Uno - UTVUnderground Approved
Jun 1, 2009
123
40
They make a dot 5.1 i think is the number that will go right in without any issues.
AZCourt
Feb 11, 2009
525
11
I machined the stock uprights and front hubs and made my own caliper mounting brackets. i just used a brembofront kit for 12" wheels. It has a ton more braking in the back now. Rocks are definatly a cause for concern, I have seen a couple wheels worn thru. Hasn't happened to me, but I rarely get to race.
