Polaris RANGER XP 900 Dune Review
Discussion in 'UTV Industry News & Product Reviews' started by Crowdog, Nov 2, 2012.
  1. Crowdog
    Crowdog UTVGuide.Net
    Jan 18, 2009
    Shingle Springs, CA
    [​IMG]
    By Jon Crowley, UTVGuide.net
    After attending the Polaris Industries 2013 Model Introduction this summer where the new RANGER XP 900 was unveiled, I was pretty impressed with this new vehicle. Polaris just didn't stuff a RZR XP 900 ProStarâ„¢ 900 engine in a RANGER XP 800 chassis. The 2013 Polaris RANGER XP 900 is a completely new, ground-up design.
    The RANGER XP 900 features a ProStarâ„¢ 900 engine that is specifically designed for work applications. It features 60 horsepower and pumps out incredible, class-leading torque and pulling power. To demonstrate the power of the new RANGER, Polaris used it to pull a dump truck. And not just on flat ground, but also uphill!
    [​IMG]
    In addition to the new engine, Polaris stretched the wheelbase by 5" and moved the engine from between the seats to under the box for a quieter ride. In addition, the all-new, durable drivetrain is built specifically to handle higher horsepower. It features the strongest belt ever in a RANGER, plus powerful cooling for belt and clutches.
    After leaving the media event, I could not wait to get my hands on a demo unit. I didn't have to wait long. In September, I got a call from Placerville Polaris that a 2013 Polaris RANGER XP 900 Sunset Red LE was ready for pickup. in addition to all the great standard features, my new LE also had:
    • 12" Black Xcelerator rims with PXT tires
    • Integrated driver's adjustable seat
    • Turbo silver painted front and rear suspension springs
    • EPS
    I quickly put it to work around our property hauling wood pellets and using it for a fence project. The RANGER XP 900 has a 1000 lbs. bed capacity and is well suited for work.
    [​IMG]
    Then in mid-October, I started to make plans with Dave Kuskie from Fullerton Sand Sports to head to Sand Mountain for Halloween weekend. I was planning to bring my new 2013 Polaris RZR XP and figured I could bring another machine with me as well. Although the RANGER XP 900 is primarily a work, the thought of seeing how it would do with the additional power sparked my interest. I made the decision to make it an XP 900 trip, RANGER and RZR!
    I wanted to see about adding sand tires to the RANGER XP 900. The bolt pattern is the same as the RZR 4-156, but the new RANGER uses a larger stud than before. The new stud is a M12x1.50 fine thread which is larger than the RZR. I decided the best way to handle this is to use a set of tires that are mounted on OMF Performance billet center beadlocks. I took the centers and drilled out the smaller lug size to 31/64" which is just a tad over a M12. And thankfully the RANGER can still handle a 12" wheel without a problem. Got it all done and the sand tires fit just right!
    [​IMG]
    After arriving at Sand Mountain, I unloaded the RANGER and RZR, grabbed Dave Kuskie and headed out in the dunes. After a few still shots, I asked Dave if he wanted to see if it would make it to the top. We buzzed over to the hill and started up the hill. First thing you notice if you are at all familiar with the RZR XP is the different tone the RANGER makes. The RPM range seemed lower to me and the exhaust is quieter. About a third way up the hill, it was obvious that we weren't going to make it, so I turned around and headed back to camp.
    [​IMG]
    I was a little bummed. But the paddle tire guru Dave told me that I needed to check air pressure before trying again. He was right. I had no idea how much air I had in the tires and should have adjusted before heading into the dunes. With beadlocks, you can run a lower air pressure which can really help the car stay on top of the sand while going up steep hills. I know people that have run as low as 3 PSI just to get up to the top of Sand Mountain. The trade-off at the low pressure is you sacrifice when you corner hard. The tire is much less stable in the turns and starts to fold in hard turns. I dropped to 6 PSI on all four corners and headed back up. It was like I had a whole new vehicle. Really amazing how it just pulled harder all the way to the top.
    With the power to get to the top under our belt, we headed out into the dunes for some riding. I tossed the keys to Dave so I could get behind the lens and he went right to work. Watching the RANGER in action it was hard to remember that I had driven it loaded with 900 lbs. of wood pellets just a few weeks earlier. It is pretty obvious that it isn't as sporty as the RZR XP, but I was thoroughly impressed with how well it did.
    With 10 inches of front and rear wheel travel, the suspension did a great job soaking up the hits from the jumps. The shocks also provided for a soft ride across the chop of the torn up dunes.
    [​IMG]
    The 60 inch width of the RANGER made it feel very stable and predictable on side hills. And with the STU Razor Blaster tires up front helping to steer on steep inclines was a breeze.
    I am a big fan of power steering in UTVs and the factory installed EPS on my Polaris RANGER XP 900 Sunset Red LE did not disappoint. More powerful at slow speeds, but not overbearing at high speeds.
    The power was adequate for the dunes, but not nearly what you would feel in a RZR XP. At 1,360 lbs, the RANGER is 170 lbs. heavier than a RZR XP, and although it has a ProStar engine, it is geared for working with more power and drivability at slower speeds. If you come from a RZR XP background, the sooner you sink that into your brain, the better off you'll be!
    [​IMG]
    I had a great time driving the RANGER XP at Sand Mountain, and I am happy that I decided to bring it along. If I was going to buy a vehicle for pure sport, the RZR XP is much better suited. But if I needed to do work, but still get out and play hard, I would seriously consider the new RANGER XP 900.
    Big thanks to Dave Kuskie at Fullerton Sand Sports for getting behind the wheel of the RANGER XP 900 while I took pics!
    More pictures from the weekend:
    Sand Mountain Halloween Weekend Photo Gallery
  2. mtoma
    mtoma Member
    Apr 30, 2010
    Jackson, CA
    Nice write up dog.
    I would've thought with the HP and torque of the new 900 along with the paddles it would've made it to the top.
    Too much weight?
    Sent from a pay phone using Tapatalk.
  3. Crowdog
    Jan 18, 2009
    Shingle Springs, CA
    it did make it to the top. Just had to air down. And the RANGER is heavier and tuned for work.
  4. Spicoli
    Spicoli Member
    Feb 26, 2011
    So Cal
    Nice write up. Seems like the new Rangers have some ability for play and not just all work.
  5. Crowdog
    Jan 18, 2009
    Shingle Springs, CA
    If I was a mud guy, I would pick the RANGER XP over the RZR XP in a heartbeat. The S3 boys built a nice one with lift/long travel that looked sick. I could also see one in the rocks with long travel and some 30" tires.
Share This Page
