I blew up my turbo 800 for the final time and was going to put a Hayabusa in it I had. After a series of event the plan was changed I sold the bus a and ended up with a 2011 xp frame that was changed because the a arm tabs where oval from a wreck. I also bought a 05 RX-1 engine from a salvage yard with a built engine and turbo kit. This is the carburator model but I got a good deal and it should still run strong. Here some pics I took along the way. You won't see anything spectacular here just making stuff work on a budget.
I started with a Racer tech gusset kit. I guess I should have taken a before pic. But here it is welded.
I took the apex wiring harness apart and cut out the stuff I didn't need. I also lengthened the wires that needed to be by soldering and shrink wrapping all the conections. The harness was the spiral wrapped and taped with good tape.
