Trying to get ready for an upcoming dezert race just wondering what jacks people are using and how they are mounting them to there cars. Post your pics thanks
I have heard of that before. It goes high enough to lift the tire off the ground.Get a small scissor jack from a small car ad weld a lug nut to the spin shaft then you can use a cordless impact to jack the car up and use the same socket to remove the wheel. Then make a mount on car that you can run the jack tight too to keep it in place. works well
Until the jack goes missing and you have a flat. ...Get a small scissor jack from a small car ad weld a lug nut to the spin shaft then you can use a cordless impact to jack the car up and use the same socket to remove the wheel. Then make a mount on car that you can run the jack tight too to keep it in place. works well
Looks like a really nice set up. Should mount nice with how I have my spare tire mounted. Also looks like they are using the same jack you guys are talking about.Check out the pro armor quick shot jack
Pro Armor Quick Shot jack.
Is this the same as the jack Baja designs was selling for a while? If so i didnt like the fact that you couldnt slow the jack and control the speed it went up/down. In other words...it seemed like it was on or off...no inbetweenhey dennison that quik shot would work great on your car we've installed a few of them and there small compact and work well!
You need a good 2 for 1....you're about a Negative F**kerUntil the jack goes missing and you have a flat. ...
I had the quick shot on my old car ... It has an aftermarket cage and I couldn't use te full Pro Armor mounting system. It fell out on the first lap of the last AVE Race and I'm pretty sure every car ran it over and it still works great !! If the rear of your cage is stock or follows similar lines it should work no problem with your car. Your close to my house so if you want to use mine for a mock up let me know . I have the whole set up still.
