The new Tensor Race tire is marked as a 32 but once mounted its taller then 32, which IMO is brilliant. Per BITD the tire can't be any taller then 32 as Marked/Stamped on the tire. It does not matter what the diameter or rolls out measurement is. Per Score you can run up to a 33 inch maximum diameter tire at 18 lbs of air pressure.
So the Tensor race tire gets the max size in both series. A year a ago I was trying to convince another tire brand to do the same thing, so the same tire could be used in the UTV class, but also be enticing for some of the limited buggy classes like 1600, 5/16, 9 and the prerun /play buggy market that run 33 inch tires. They did not see my vision obviously! LOL!
BTW if anyone is getting 2K miles from a race tire, it for one is not soft! Two I would like to see it as that would be very impressive. I would expect to see some serious chunking.
