What brand steering wheel quick connects are you guys using? I have a gear-one and I am having problems with sand getting in it and galling the 2 pieces together. Also....I am not looking for the bolt on style.
Thanks
Thanks
I just spoke with BRP....evidently I have a bastard bolt pattern. I am gonna give ORW a call right quick and see if there adapter has the right patternhere is the link tot he info on BRP's quick release. It looks bad ass and no fab work required!!! HUGE PLUS!
http://www.utvunderground.com/f52/new-steering-wheel-quick-disconnect-no-welding-2129.html
is this 3-5-or 6 bolt???What brand steering wheel quick connects are you guys using? I have a gear-one and I am having problems with sand getting in it and galling the 2 pieces together. Also....I am not looking for the bolt on style.
Thanks
The steering wheel has a 3 bolt pattern. Most 3 bolt patterns are on a 1.5" circle. My momo is one a 1.75 circle......(actually its probably metric but very close to 1-3/4) I have my doubts that the 6 bolt pattern adapter I am getting is going to be right.is this 3-5-or 6 bolt???
dansperformanceparts.com has these.
well steering wheel and owner are alike huh??I just spoke with BRP....evidently I have a bastard bolt pattern. I am gonna give ORW a call right quick and see if there adapter has the right pattern
I believe there are three hole ones that have both smaller and larger 3 bolt pattern in the same adaptor. you are correct, there are two diff three bolt patterns out there.The steering wheel has a 3 bolt pattern. Most 3 bolt patterns are on a 1.5" circle. My momo is one a 1.75 circle......(actually its probably metric but very close to 1-3/4) I have my doubts that the 6 bolt pattern adapter I am getting is going to be right.
Steering wheels- Page 3
call Dan, great guy. 760-751-0718 and ask about this.
Rog
I dont know who I spoke to....But the momo pattern is cose to 2.5 bolt circle...I layed that out in autocad and between ever other bolt is about a 2.165 straight across. Si the adaptor they are sending me most likely will not workJim who did you talk to at ORW. Talk to Dave,he is a pretty bright guy. He is at the Escondido store and is known as RHinoKing here on UTVUG.
the grant will fit the three hole one from Dans, I have used those before.Does anyone know if the Grant/GT pattern is going to work with any one of these? Just want to make sure I buy the right one. Its 3 bolt I beleive, wanna make sure its the right 3 bolt.
Ya...I called him. He told me both 3 bolt patterns are the sameI just checked out Dan's. There are several places he mentions "Universal 3 bolt pattern.", but I can't find any reference to a 2nd 3 hole pattern. I see different shaft sizes.
Just looked again, there is an adapter, 14-840103, that looks like it has 2 3 bolt patterns. Might be worth calling to check on it.
