Our New F31LKSG 5th wheel Stellar 2010
Eclipse RV
Toy hauler - UTVUnderground Approved
Jan 23, 2009
45
Riverside
www.cruiserrv.com
Grease Zerk's on all Suspension Bolts to help prevent wear from off road use the only MFG in the industry that understands what our customers do with there haulers...
For those customers that want to run dual A/C's on a small 5th wheel this Gen has you covered...
Hitch Weight 1,690lbs.
Axle Weight 7,540lbs.
Total Unloaded weight is 9,230lbs.
MAX GVWR 12,500lbs
Eclipse RV
Jan 23, 2009
45
Riverside
www.cruiserrv.com
Vacuum-Bonded Aluminum Framed Gel Coated Side Walls
Radius Cabinets Ends
12 Volt Hitch Light
Fully Insulated w/R-8 Floors, Walls, & R11 Roof
Northern Mountain Package
7’ Ramp Door w/ Dual Handles and Oversized Springs
94.6†Ramp Opening
Wide Track Axle System W/Quad Electric Brakes
6000 Lb. Axles w/12x2 Electric Brakes w/7000 Lb. Per Axle Stopping Capacity
Zieman Chassis
Off-Road Suspension
Omni Radius Windows and Entry Doors and Baggage Doors
1.50 Quick Water Drain
Dual 7.5 Gal. LP Tanks
Back-Up Lights
1-Pc. Rubber Walkable Roof
Hex Plate on Front and Sides
16†8 Lug Tires and Rims
Dual Queen Electric Beds
Dbl. Studding in All Stress Areas
LP Leak Detector/Carbon Monoxide Detector
Chrome Rims
50 Gallon Grey and Black Tanks
136 Fresh Water
Bed room A/C 13,500 BTU Air Conditioner
Living room A/C 15,000 BTU
Electric Awning
Microwave Oven
Large Dbl. Door Refer/Freezer
Sony Sound system AM/FM/CD w/4 Speakers
Exterior Pressure Sprayer
E-Z Glide Omni Radius Steps Triple Steps
Solid Oak Framed Cabinet Doors
All Cabinet Faces Screwed
18†Overhead Storage Cabinets
Ladder
3 Burner Range with Oven 17†with Piezo Igniter
40 & 60 Amp. Xantrex Battery Charger/Converter
Tinted Radius Windows
Deluxe Valances with Lambrequins
Night Shades
Euro Chair's
Full Lino Covered Floor
Flush Mount Tie Downs
12-Volt Fan in Bath
Laundry Hamper
15" LCD Bedroom TV & 26†LCD DVD TV Combo living room
Power TV Antenna W/Cable Hook-Up
Omni Radius Roof Edge
Dometic Appliances
Goodyear Tires
Turbo Air Vents
6 High Intensity Flood Lights
2 High Clearance Jacks
Porcelain Toilet
Carpet Kit
Rear Ramp Screen Wall
5.5KW Onan Generator
36 gallon Fuel Station and Fuel Gauge
FX Package
Outside Speakers
Spare Tire & Carrier
Bryan M
B-MAN - UTVUnderground Approved
Jan 16, 2009
189
7
Sin City(Vegas!)
I have the 2007 ww fs2600 which is really close to this floorplan but is a bp instead of a 5er and I man do I wish this model was out then, I would have been sold.......course now that ww lifestyles is honoring the ww warrantys maybe I could sell and .....hmmmm
