Hey guys, just wanted to show you how i relocated my oil cooler on my Rhino, welded 4 tabs to the frame, cut the steel oil lines, added about 18" of rubber hose and moved the oil cooler above the radiator. now the rad gets all the fresh air. I did take the stock fan and moved it ontop of the oil cooler and purchased a new Flexfan and added that to the radiator. I then added all of this to a Bosh relay and added a toggle switch, it will now come on by its self, or i can turn it on using the switch. Oh ya the hood scoop adss about 20 hp.
