Yamaha Oil Change??
FernandezRacing
484
5
How much oil is needed to change the oil in the rhino 660? Dont have the owners manual,and on dial up. What weight oil should i use for so cal,
10w40 or 20w50???? Anybody with answers,It would be well appreciated.
Thanks,
FernandezRacing
kdub41
Murder Red
Jan 27, 2009
242
34
Hemet
I am going to use 20w50 amsoil, because amsoil is the best i used it in my quads and it is amazing. and im going to run amsiol 80 90 in my differentials. Amsoil keeps the motor running cooler and better lubrication, meaning higher viscosity. Amsoil is not cheap but it does the trick and will last longer than the other oils. Hope this helped
az_amsoil
Jan 22, 2009
593
The kits I sell use 0W-40 motor oil and 75W-90 gear for the diffs. Yamaha recommends an SAE 40 weight. Engine take 2.25 quarts, final drive takes 0.25 quarts and diff take 0.35 quarts
FernandezRacing
484
5
Thanks guys ..Changing the oil in a couple days..
Any recomendations on oil filters ,Temecula motorsports said the k&n oil filter voids the motor warranty...Whats best????????????
az_amsoil
Jan 22, 2009
593
The K&N will not void the warranty (but some have reported the filter coming loose and dumping your oil!)...my kits include a WIX 51358...NAPA, Puralator and Yamaha are good too
frankcarpenter978
