We will be there in the DragonFire Racing booth! Come see me and get your raffle tickets to win lots of great prizes and check out my awesome Can-am Maverick!
Yep same as last year, right next to Toyota. See you there!Your our first stop on the way in. You across from berts utv again?
What's the range on this 5 watterGet the Camo RH-5R for $50, (reg. $85) available only at the expo!
We'll be in building 4, booth 4113
Approx. 2.5 miles, which could vary more or less depending on type of terrain. Most all handheld radios are 5 Watts or less (Due to FCC limitations) but the 5R should get the same range as much more expensive handhelds because they're all running at the same power level.What's the range on this 5 watter
Does it have a battery and charger?Approx. 2.5 miles, which could vary more or less depending on type of terrain. Most all handheld radios are 5 Watts or less (Due to FCC limitations) but the 5R should get the same range as much more expensive handhelds because they're all running at the same power level.
