Baja Designs has developed a plug and play kit designed for 2015+ XP900 and 2014+ XP1000 RZR's
This OEM, Polaris RZR 30" OnX6 Roof Mount Kit is designed utilizing stock mounting locations and takes all of the guess work out of installing a 30" OnX6 on top of the Stock Cage.
****Designed for use with Stock Cage. Will Not work with Factory Plastic Visor****
****This is just a visual representation showing how the kit will look mounted****
45-7533
$1149.95
This kit comes equipped with a 30” OnX6 LED light bar and a vehicle specific wiring harness for an easy plug and play installation.
The OnX6 LED light bar utilizes our trademarked High Speed Spot™ reflector, the same one used by our Team Enlightened racers, to give you the guaranteed furthest projecting LED Light Bar on the planet.
At an impressive 19,350 lumens, the OnX6 is BRIGHTER. BOLDER. BETTER. An industry first 30 Day Satisfaction Guarantee & Limited Lifetime Warranty is included for the ultimate in purchase protection.
Thank You,
Bailey, Baja Designs
45-7533
$1149.95
Thank You,
