My new/old tow rig 1975 Ford 4x4 Crew Cab ;-)
Cisco Kid
Apr 17, 2009
7,862
81
Well here she is, she pull awesome power to spare ;-)
That the good news ;-)
z28_killer
Sweet old ford man! I want to build a sweet tow pig like that for haulin our camper/boat around.
What are the specs on that rig? Do you have a build thread somwhere on it?
Again sweet rig!
Cisco Kid
Apr 17, 2009
7,862
81
On my way home 3 blocks from home a rear axle come out, good thing I did not have the TH and was a stop sign ;-(
dkiewicz
Nov 28, 2009
1,582
58
66
Hesperia Ca
Did you rebuild the diff? I don't remember seeing that. Whew!!! That could've been REAL bad!!!:eek:
dkiewicz
Nov 28, 2009
1,582
58
66
Hesperia Ca
w t f ,was that a beer day, just 4 simple nuts
No, there's some "C" clips that go on the axle in the carrier. Those can break which will release the axle, and they can come out. They also fall off real easy when your putting things back together and if you don't check you can miss them.
This could've turned out much worse!!! Hopefully he didn't gall the bearing with the off center weight.
Lucky day for Mr. Cisco!!!!
<center>
</center>
tomcav
Let ride ,bitches
Feb 6, 2011
1,368
55
the oc
<CENTER>
</CENTER>
it looks like a full floater diff ,not the simple c-clip type, who knows maybe cisco will chime in .......
dkiewicz
Nov 28, 2009
1,582
58
66
Hesperia Ca
Nope, I just rebuilt my boys FS Bronco 8.8" LS diff and it also has the same thing. There's an S spring that goes in the middle once the clips are on that keep the axles in place.
ROTAX
CannedHam - La Familia
Feb 21, 2011
4,566
185
Thats a beautiful truck Cisco, ...not as pretty as my F350, but I love it ;)
Cisco Kid
Apr 17, 2009
7,862
81
<CENTER>
</CENTER>
No "C" Clip ;-)
Cisco Kid
Apr 17, 2009
7,862
81
Axle = it still good
Drum = no bueno
bearings = no bueno
nuts = no bueno
and the $1.00 locking washer that did it all = no bueno
going to try and fine a heavy duty one ;-)
Maybe the Truck has to much Torgue ;-)
dkiewicz
Nov 28, 2009
1,582
58
66
Hesperia Ca
Check the spider gears for end play. There's also a cupped spacer that goes between the top and bottom gear that can also allow some free play. Some folks don't put this back when they rebuild, but it needs to be there.
I'd say it was just old and broke, they have the same diff in pro stocks that have that much HP or more and they hold up, so just old.
Your diff is a limited slip, right?
Cisco Kid
Apr 17, 2009
7,862
81
Yup Dana 60 ;-)
