So I've decided I'm tired of the yellow on my xrs. I ordered some samples and decided to wrap all my yellow in a satin pearl white. I got a smaller piece to try it out before I order enough to do my maverick. I figured I try it on the hood piece since it was smaller, easiest to take off and had a few contours on it. It was a lot easier than I thought t was going to be.
The vinyl I am using is 3m 1080 scotchprint. It was designed for wrapping cars so it's meant to be easy to work and stretch to go into deep recesses and body lines.
I had a few scraps so I was messing around with the knife-less tape for cutting the vinyl without cutting into your plastic. You can cut designs and stuff with it very easy and it's cuts the vinyl really nice.
I'm also wanting to add some more color probably green or blue... Or maybe both. So I will get more vinyl on the way and keep you guys updated as soon as I get more done.
