Limit Strap Kits Available for X3 RS Now
Shock Therapy
Suspension Tuning
Aug 10, 2014
59
Arizona
Finally a cure for the front end CLUNK in the X3! As most people know, at full extension the shocks can make a loud clunk that feels like a hammer against the chassis. If you run aftermarket, heavier wheels and tires this clunk gets much worse. Although the shocks have extension stops internally they are tuned to the factory wheel and tire weight and can't manage any changes in the system so a front end clunk has become the new NORMAL in UTV's. Well, not any more. Our new limit strap kit stops the front end clunk instantly. Limit straps have been used in racing for decades. Trophy trucks and other big off road racing classes have considered them a must forever and so should you. Some of the benefits with our limit strap kits are:
PATENTED, billet aluminum, laser engraved, upper strap mounts
Adjustable, tight clearance clevis system allowing you to adjust the strap length perfectly
Quad layered straps for the best strength and longevity
PATENTED, tether system that locates the strap next to the shock at full compression
Accurate sized holes in the strap ends to match the metric hardware in your car
Stainless steel spacers that don't rust or flex like aluminum spacers can
Grade 8 hardware with pinch nuts
Mounting system with the least leverage on the strap
Less strap stretch and longer strap life
Added life for your CVs and Axles and STOPS ALL EXTENSION CLUNKING!
The best fix for your front end noise is here. Limit straps are standard issue for racers and now they should be for YOU too! Cost is $269.95.
Link to the product on our site: http://shocktherapyst.com/can-am-x3-rs-front-limit-strap-kit/
Kits for the DS are coming soon. Rear kit for the RS is also in the works. This kit is on our site now and installation video will be up tomorrow. Thank you
Video below
Shock Therapy
Suspension Tuning
Aug 10, 2014
59
Arizona
Here is our install video for the X3 strap kit. Take a look if you want to see how easy this kit is to put on. Thank you!
