Make sure you prep & pretrip your trailers, tonite while greasing the wheel bearings on ours I found only one bolt (out of four) holding the brake backing plate on, it would seriously suck if we had a brake or bearing failure on our way to Utah so make sure you do your maintenence. I do bearings every other year and am doing them a year early due to the miles we will travel with LOORRS and this still happened.
Little time in the driveway save you alot of headache on the road.
