You got some "explain to do Lucy"Isn't that mount for the elite 5m? Do the holes even line up? If they do the face plate should come off the GPS and the bolts that you have to provide go through the front
The holes do line up and I drill the ones on the Bracket to the right size - no bolts came with the bracket
Bolts are not the problem is no where to bolt it to, this GPS does not have what the elite 5m has in the back ;-(I see. I've had to buy bolts for all of my GPS mounts. Stop by ace hardware and problem solved. An Allen head usually works best as it is recessed in the GPS.
