Fuel Cell Set-Up Help
speedyangie
The Need, The Need For SPEED.......UTVUndergroun d
Jul 31, 2011
365
Cali
I have a BDL regulator and a Bosch pump, but I think the pump is pumping too much fuel or the regulator isn't regulating it.
BrianReno
Aug 19, 2012
202
13
Reno, NV
Do you have a pressure gauge on or inline with the regulator? Is your regulator adjustable? EFI generally runs in the 45 to 55 psi range.
speedyangie
Jul 31, 2011
365
Cali
Yes, pressure gauge on the regulator. Regulator is adjustable...checked pressure going to fuel rail and it's at 70 psi after changing to a new pump rated at 45-65 psi. Maybe regulator is bad? Trying new regulator today.
speedyangie
Jul 31, 2011
365
Cali
Am I missing something? Breather? Filter? Return? What's the set-up supposed to be?
megadesertdiesel
Jan 25, 2009
1,838
73
Mesa, AZ
The aeromotive regulator I used had 5 ports. Out and 4 return locations. I just blocked off the 3 returns I did not need. I ran 40 psi to a r1 engine.
You need supply to fuel rail, return to tank, and vent from tank to high on rollcage with a 360* loop.
speedyangie
Jul 31, 2011
365
Cali
Okay. The regulator I have has three ports and a spot for a fuel pressure gauge. I have a gauge on there, one port that's being fed from the pump, one return to the block and one blocked off. I have a hose venting from the fuel cell that I'll run up...and as you said 360*.
speedyangie
Jul 31, 2011
365
Cali
I'm getting a different reading from my pressure gauge on the regulator and a gauge that I have directly on the fuel rail.
speedyangie
Jul 31, 2011
365
Cali
I think we have it figured out. First we were running too crazy of a pump. That ruined our regulator even after changing the pump. So, after changing the pump to one rated at 45 psi and putting in a new regulator. We're golden!
speedyangie
Jul 31, 2011
365
Cali
So, it worked but didn't work at the same time. I keep ruining my fuel pump. Ideas?
My set-up is - fuel cell, fuel pump to fuel regulator (two port in/out and return).
What's the problem?
BiggJim
2,079
452
Bakersfield
I am not sure if the S model has a return, but the xp does, its on the other side of the fuel rail, just route it back to the tank.
c&c rhino
Jan 18, 2009
351
11
lake elsinore, ca
do you have a pic of the stock tanks pickup/pump setup? good thing about a fuel safe is the large oval steel center plate. after many headaches on 4 cylinder ford rangers i just mounted the stock pump/pickup/sending unit in the oval plate and called it a day.
