after blowing up three $180 CanAm belts, and my secondary clutch bolt comming loose 2 seperate times i finally said screw it and ordered up a STM Rage 6 and STM secondary through //Airdam clutches. I spent some time on the phone with Adam explainning on how i drive and told him i wanted a bullet proof setup.
I got the Rage 6 with steel spider and tuner secondary. I sure hope this fixes all of my clutch issues, because it was not cheap to buy.
off to Glamis tomorrow.
first ride around the block was ok, i put a new belt on it so i was fairly easy on it. The clutch is butter smooth and no noise from it at all.
i used valve lapping compound to set the tolerance tight.
