Kawasaki 2012 Kawasaki Teryx 4 750 4x4 OFFICIAL RELEASE **UTVUnderground Exclusive**
18,569
1,368
113
North County San Diego
www.utvunderground.com
2012 KAWASAKI TERYX4â„¢ 750 4x4
Orlando, FL , October 15, 2011 - UTVUnderground.com is the ONLY forum based site that has been invited to the 2012 Kawasaki Dealer show here in Orlando, FL. The show Kawasaki is putting on here is like none I have ever seen before. Later today I will post images LIVE from the show which will include more angles strait from my lens! I will also include images of the Funco Motorsports built Kawasaki Teryx 4 which includes Funco Long Travel and a custom Funco Cage.
UTVUnderground.com has been in the know on this project for I want to say 1 year now. The first time I laid eyes on it at the Team Green racing garage I knew it was going to be a winner. Like many of us I look at right away and say ok, I want a LT, Shocks, Chopped Cage, Seats, and all the other goodies!! lol It is a new platform with the standard Kawasaki quality we have all become accustomed to.
Kawasaki has been working on this project for a long time and our very own Team Green Reid Nordin has been a driving force in its devolpment which means a REAL UTV guy giving REAL input and feedback. This has forced engineers to change things more than few times to really dial the Teryx 4 in.
Now before you all freak out on why the same size engine, let me tell you what I know. The NEW 750 engine is ALL NEW. Existing 840 kits and such will not work. It is going to require some new performance R&D but I can tell you Kawi did their homework. This new engine not only has new power it also has potential for more power. I have been told that every phase of the engine has been improved and made even more bullet proof. It is a better engine through and through and the new clutch is something that no one else has done yet.
I can't wait to get my hands on our unit. Expect a full build this year!!!
"LET THE GOOD TIMES ROLL!!"
All the Performance, Style, Function and Fun
You Expect from a Teryx 750 4x4 – with Room for Four!
Twice as much of a good thing is always better, right? Absolutely. So you knew Kawasaki would eventually double the Teryx’s substantial fun and function factor by adding two seats – enough for more friends, extra help or the whole family.
The result is the all-new 2012 Teryx4™ 750 4x4 – a top-of-the-line four-seat RUV with truly amazing capabilities. Of course, Kawasaki didn’t just bolt two extra seats to the Teryx 750’s chassis and call it a day. Engineers figured out exactly what was needed to do the four-seat Rec/Utility concept right, redesigning the entire machine from tip to tail with an all-new chassis and a thoroughly reworked V-twin engine pumping out extra power for the additional load the Teryx4 will gladly carry.
The foundation of any top-tier RUV four-wheeler – especially one with four seats and significant carrying capacity – is its frame, so Kawasaki engineers used detailed computer analysis and loads of off-road testing when developing the Teryx4’s all-new square-tube steel frame. Unlike the more conventional designs found on many lighter-duty two-seat RUV models, the Teryx4 features a Double-X frame design with two X-shaped cross members bridging the box structures from corner to corner.
Like the frame, the Teryx4’s 749cc V-twin four-stroke engine is also new, offering 15 percent more power than the already stout unit in the 2-seat Teryx, along with all the durability to deal with the rigors of spirited fun in challenging off-road environments. The V-twin design is revered for its stump-pulling power and easy-to-harness flexibility, which makes it the perfect powerplant for a machine like the Teryx4, which thrives on instantaneous and controllable low- and mid-range response partnered with eye-opening hauling ability. In fact, engineers purposely gave the big Vee a bit of a dual personality: there’s exciting, arm-straightening yank when ridden solo or with a single passenger, but plenty of torque and grunt for carrying more people or heavier loads – much of it due to revised camshaft profiles and equal-length exhaust headers.
Liquid cooling – assisted by a large-volume radiator and large-diameter fan – keeps temperatures down and reliability up with help from an array of superb engineering: optimized piston-wall thickness; special surface treatments to piston pins, small and big end bearing surfaces; idealized crank journal bearing sizes; robust transmission design; and much more.
Electronic fuel injection – featuring new fine-atomizing 12-hole injectors – offers easy starts and perfect throttle response at sea level and at the higher elevations you’ll want to discover again and again. The FI system offers automatic mixture compensation, automatic idle adjustment and easy, choke-free starting via a sophisticated array of sensors for inlet air pressure, throttle position, crankshaft position, rpm and coolant temperature.
The Teryx4’s 90-degree V-twin engine is also super-smooth, its perfect primary balance keeping things comfortable for driver and passengers all ride long. Routing all that impressive and usable power to the wheels – and ground – is the latest in modern drivetrain technology: a Continuously Variable Transmission (CVT), a category-first centrifugal clutch assembly and an electrically selectable 4WD system featuring instant-switch access to 2WD, 4WD and 4WD+Front Differential Lock system. The CVT is well known for its quick response and direct engine “feel†in sportier riding situations, where engine power is used to control the chassis while turning and in rough conditions. The key to the Teryx4’s dual-mode personality is its category-first centrifugal clutch, which offers an extra degree of precision slow-speed power manipulation and smoothness, which is ideal for tricky terrain (rock crawls, etc.) or slow-speed work where precise throttle manipulation is key. The oil-bathed clutch design also contributes to improved CVT belt life by lessening shock and belt deflection.
The electronic 4WD system allows drivers to easily change between three different drive modes for most situations they find themselves in: 2WD (light steering) for maximum sporty performance, 4WD for enhanced traction while keeping steering relatively light, and 4WD+Differential Lock for maximum traction situations. A dash-mounted switch makes switching between these modes easy, and changes occur instantaneously so the driver remains in complete control at all times. So whether it’s climbing a slippery and rocky uphill trail, negotiating a wet stream bed, hauling lumber for fixing fences on the farm, or hauling butt down a wide-open two-track, the Teryx4’s got the traction and drivetrain mode to handle it.
All this superb handling ability is aided by a number of factors, including a wide-track/wide-body chassis design that contributes to superb cornering characteristics. A wide track resists the body roll that accompanies cornering forces, and helps the chassis cope with rough terrain at speed. The Teryx4’s mid-ship engine placement also helps by centralizing the vehicle’s center of mass and minimizing the inertia that accompanies direction changes.
Of course, sport-focused independent suspension helps, and the Teryx4’s got plenty. Again, engineers opted for a dual-mode design; that is, the suspension works in a comfortable way with four passengers aboard, but also performs like a sporting RUV in a solo mode or with a single passenger. It’s a difficult combination to get right, but high-grade componentry helps out. Up front are high-performance single-chamber gas-charged and preload-adjustable shocks complemented by an anti-roll bar, which allows an ideal front/rear roll balance and added ride comfort. In back are fully adjustable shocks with piggyback reservoirs, which offer additional oil flow for cooler temperatures and more stable damping performance.
With all this speed and handling potential, excellent brakes are a must, and the Teryx4 delivers in a big way. High-performance hydraulic discs up front using 200mm rotors gripped by dual-piston calipers offer exceptional feel and stopping power. The brakes are recessed within the wheels, protecting them from dirt, water and debris, while durable steel-braided lines help keep lever feel crisp and progressive. In back is Kawasaki’s unique sealed internal wet brake, similar in design to the highly acclaimed disc system used on our award-winning ATVs and two-seater Teryx models. Internal components are completely sealed from mud, water, dust and debris, the result being ultra-reliable braking performance in most conditions. The combination of powerful discs up front and the sealed system in back is ideal, and contributes once again to the Teryx4’s wide-ranging overall performance.
Large 26-inch Maxxis Bighorn 2.0 tires are the largest available in the RUV category, and offer the type of ride comfort, control and traction you’d expect from an RUV this capable in so many different environments. Their tread and carcass design help maximize forward traction while at the same time optimizing control for aggressive cornering.
The Teryx4’s unique chassis dimensions help in the areas of turning, climbing and working, too. Its relatively short (compared to other four-seat RUVs) 85.7-inch wheelbase affords it a surprisingly small 16.7-foot turning radius, which makes tight turns an easy affair on trails or in tight spaces. The unit’s substantial ground clearance (10.8 inches) helps keep it from bottoming when cresting a ridge or rolling an obstacle, while high approach and departure angles (79 and 65 degrees, respectively) thanks to minimal bodywork overhang reduce the possibility of smacking the front bumper when approaching a steep slope or scraping the tail when exiting one.
Did someone mention work? The Teryx4 excels at all sorts of 9-to-5 or leisure-oriented jobs, from hauling to transportation to towing, from small jobs to really big ones. Its 250-pound-capacity cargo hold is sizeable, measuring 18 by 48 inches, with an 8.5-inch depth. The flat-bottomed space is big enough for a large cooler, spare fuel cans or other large objects, and four tie-down loops help secure cargo safely. The rear wall is shorter in the center, which makes it easier to load and remove items. Towing capacity is a staggering 1,300 pounds.
Convenience features include DC sockets – one in front, another in back – providing a total of 120 watts of electrical power, while nearly 8 gallons of fuel capacity offer substantial range, enough for a long day of work or trekking. There’s a drink holder for each of the four seats, while an auto-style parking brake activates the sealed rear brake setup, to aid parking even on a slope. Getting at the front suspension, coolant reservoir, air filter and electrical equipment is easy thanks to an easy-open front hood, which is part of a body package that’s stylish, rugged and rugged-looking.
Those powerful and purposeful good looks start up front, with a stylish hood, beefy steel front guard, headlamp and fender design that gives the Teryx4 a no-nonsense look that says “sporty†and “functional†in the same breath. Standard doors front and rear are easy to use, look good, and offer a level of mud protection. Scratch-resistant bodywork and textured paint on the ROPS framework and front guard help keep the Teryx4 looking good for a good long time, too.
You’ll enjoy riding in the Teryx4 for a good long time, too, because it’s the most comfortable RUV in its class by far. Its roomy interior gives driver and passengers room to spread out, with plenty of hip, shoulder and legroom. High-backed bucket seats and three-point seatbelts offer a high degree of comfortable security, while urethane cushioning and cold-resistant elastic seat material provide all-day plushness. The adjustable front seats offer three positions in one-inch increments, while the back seats are mounted slightly higher than those in front to give passengers a better view forward and an easier time getting in and out. Handholds integrated into the frame give passengers extra security, while comfort mounts and an anti-cinch feature on the seatbelts helps prevent over-tightening when the belts lock during sudden deceleration (or when the tilt sensor is activated). Helping ensure riders wear their seatbelts is a handy seat-belt use reminder light, which remains lit if the driver’s belt isn’t buckled.
Instrumentation is top-notch, and includes a multi-function electronic display that provides a ton of useful information: Speedometer, fuel gauge, odometer and hour meter, clock, dual trip meters, 2WD/4WD indicator, front differential indicator light, parking brake indicator, water temp and fuel injection warning indicators, reverse indicator light, etc. – everything you need to know.
Power. Comfort. Convenience. Hauling and towing ability. Reliability. Four wheels. And now, four seats. Our Teryx model line has always been a pinnacle of off-road fun and function. And for 2012, there’s twice as much to like about it.
A large selection of authentic Kawasaki Accessories is available through Kawasaki dealers for the 2012 Teryx4 750 4x4. As with all off-highway vehicle recreation, Kawasaki encourages RUV drivers to drive responsibly and to respect the environment.
Kawasaki Motors Corp., U.S.A. (KMC) markets and distributes Kawasaki motorcycles, ATVs, personal watercraft, utility vehicles and recreation utility vehicles through a network of more than 1,350 independent retailers, with an additional 8,000 retailers specializing in Kawasaki power products and general purpose engines. KMC and its affiliates employ nearly 3,100 people in the United States, with 300 of them located at KMC's Irvine, California headquarters.
Kawasaki’s tagline, “Let the good times roll.â„¢â€, is recognized worldwide. The Kawasaki brand has become synonymous with powerful, stylish motorcycles for over four decades. Information about Kawasaki’s complete line of recreational products and Kawasaki affiliates can be found on the Internet at Kawasaki Motorcycles, ATV, Jet Ski Watercraft, Utility Vehicles, Recreational Utility Vehicles.
2012 Kawasaki Teryx4â„¢ 750 4x4
Features and Benefits
Key Features
− All-new model for 2012
− Room for four means twice the personal payload and twice the fun. And with the rear seats mounted higher than those in front, rear-seat passengers have a better view forward – and have an easier time getting in and out
− Perfectly balanced 749cc V-twin engine with digital fuel injection offers more power, especially in the low and mid range, exactly where a four-seat RUV needs it
− All-new Double-X frame design offers rigidity and durability for the Teryx4’s extra weight and higher carrying capacity
− All-new bodywork package offers good looks and extreme durability for the long haul, with scratch-resistant material used throughout
− Sport-focused suspension front and rear offers an ideal compromise between sporty control and superb ride comfort
− Roomy interior lets driver and passengers stretch out, while ample cargo space means you can take along plenty of supplies and gear
− Short wheelbase versus the competition allows a short 16.7-foot turning radius (handy in tight situations) and the ability to climb over obstacles that would ground longer and lower vehicles
− Superb off-road ability, including high-grade Maxxis Bighorn 26-inch tires on 12-inch rims, 10.8 inches of ground clearance, a 17-degree break-over angle, and 23.6-inch water fording depth
− Continuously variable transmission (CVT) and category-first centrifugal clutch offer sporty performance and the slow-speed throttle precision needed in tricky or slow-speed conditions
− Electronic three-mode 4WD is controlled by a handy cockpit switch and allows instantaneous changes from 2WD to 4WD and 4WD with differential lock for maximum traction situations
− Dual 200mm front discs and a sealed multi-plate rear brake system help provide stopping power
− Convenience features include standard colored doors, auto-style parking brake, roomy cargo area with four tie-down loops, full instrumentation, hand-holds, two-tone seats, over fenders for mud protection, opening front hood for easy maintenance and much more
− Multi-function instrumentation offers the driver a host of important information, including speed, hour meter, fuel level and much more
Liquid-cooled 749cc V-twin Engine
− Teryx4’s perfectly balanced liquid-cooled, 749cc SOHC, four-valve-per-cylinder fuel-injected, 90-degree V-twin engine pumps out substantial power, especially in the low- and mid-range, precisely where a four-seat RUV needs it
− Peak power has also been raised in addition to the focus on low- and mid-range grunt
− Oversquare (85 x 66mm) engine dimensions and high-flow four-valve cylinder heads contribute to the Teryx’s superb acceleration, low- and mid-range pulling power and overall engine flexibility
− 90-degree V-twin configuration offers perfect primary balance, resulting in low engine vibration and maximum comfort for driver and passengers
− Transmission design features a shift-drum/shift-fork assembly for improved operation and durability, along with a centrifugal wet clutch in place of the previous belted design for improved operation
− Aluminum cylinders are electrofusion-plated for light weight and excellent heat dispersion – all of which add durability and reliability
− Valve timing, lift and ignition timing have all been optimized; along with a revised exhaust system, the new powerplant pumps out ideal power for a four-person RUV
− Piston wall thickness, connecting rod bearing surfaces and crank journal surfaces have all been upgraded for added durability
− Engine can be started in gear as long as the brake pedal is depressed
− Electronically controlled Kawasaki Engine Brake Control helps to slow the RUV when descending hills
− Engine is positioned mid-ship, providing optimum front/rear balance and optimal handling
− A heavy-duty liquid cooling system keeps temperatures under control in the harshest conditions, and provides long-term dependability
− Large-capacity radiator is compact and placed high in the chassis for protection against mud and debris, while a large cooling fan increases cooling capacity, especially during slower going
− Engine weight is reduced via numerous advanced technologies, including lightened crank webs, rare earth magnet usage, a small generator, and paring excess material wherever possible
− An ignition cut-out protects the brake system by preventing riding with the parking brake engaged
− Large-diameter cooling-system hoses maximize coolant flow and overall capacity, while the coolant reservoir is located beneath the flip-up front cover for easy maintenance
Digital Fuel Injection
− Upgraded digital fuel injection system enhances throttle response and automatically adjusts for changes in temperature and elevation for optimum performance in a wide range of environments
− The Teryx4’s FI system is controlled by a 32-bit ECU and continuously monitors coolant temperature, air intake temperature and pressure, throttle position, vehicle speed and crankshaft angle to automatically provide the ideal amount of fuel via two 36mm throttle bodies – now with 12-hole fine-atomizing injectors – for extremely stable power delivery regardless of the conditions
− FI system permits easy engine starting at low temperature and utilizes an Automatic Idle Speed Control and Automatic Fast Idle function to help ensure smooth engine warm up
− The high-pressure fuel pump located within the tank features a unique reservoir chamber at the bottom of the pump to ensure air does not leak into the fuel system
− Specific Teryx-sized throttle bodies, optimized ignition timing and new fine-atomizing injectors maximize low- and mid-range torque as well as offer improved response at higher rpm
Kawasaki Automatic Power-drive System CVT
− Featuring high and low ranges, plus reverse, this advanced and continuously variable transmission provides extremely direct engine feel along with instantaneous acceleration from the new centrifugal clutch
− Transmission utilizes a high-grade, super-durable Kevlar-impregnated belt designed to handle the high output of the engine. The drive converter shaft is hard chrome-finished for added durability
− The CVT Belt Protection System prevents tire freewheel, improves rocky terrain performance and reduces belt overloading by adding Throttle Position Sensor (TPS) data into the system
− Unnecessary belt wear is minimized with a system that reduces engine speed if the engine operates at high rpm for more than two seconds while the rear wheels are motionless
− A large intake duct, located to keep water and debris out, provides plenty of cooling air to the CVT
− Heat shielding on the exhaust pipe below the intake duct minimizes intake temperatures
Electronic Power Steering (EPS) System
− Electrically powered system reduces steering effort, especially at low speeds when turning effort is greatest
− Input from vehicle speed and torque sensors determine the amount of steering assistance required from the system’s motor
− Electric motor’s inertia reduces bump steer and kickback to the steering wheel caused by shocks to the wheels, resulting in a more comfortable and controlled ride
Category First Centrifugal Clutch
− The category’s first use of a centrifugal clutch is key to the Teryx4’s superior acceleration control at slow and very slow speeds
− Clutch is located between the crankshaft and CVT drive pulley, which eliminates CVT belt shock and contributes to optimal throttle control and precise power metering
Underhood Snorkel Air Intake
− New snorkel and duct design located under front hood and massive air box – nearly three times larger than the standard Teryx’s unit – feeds the engine plenty of clean air while reducing intake noise. Easy maintenance design promotes long engine life
− A new paper air filter element offers plenty of surface area and increased dust resistance
Selectable Four-wheel Drive / Variable Front Differential Control
− Selecting two- or four-wheel drive is as easy as pressing a switch located on the dash; electrically selectable 2WD/4WD/4WD w/differential lock system engages instantly
− Limited-slip front differential reduces steering effort under normal four-wheel drive operation, while Variable Front Differential Control permits the rider to distribute torque equally to left and right front wheels for maximum traction via a hand lever located between the seats
− Rear gear case keeps rear wheels locked and turning together for maximum forward thrust
Double-X Frame Design and Wide-body Chassis
− All-new frame features a Double-X design that bridges each of the boxed sections with cross members that significantly stiffen and strengthen the overall structure, adding durability and reduced flex
− Large-diameter yet thin-walled tubular steel frame combines high rigidity, light weight and mid-engine placement – a perfect combination for performance riding
− Tubular cab framework meets SAE J1194, 7.1.1, 7.1.2, 7.4 and 7.5 requirements as a roll-over protective structure (ROPS) and protects driver and passengers from trees, bushes and other overhanging obstacles
− Steel guards protect the engine from rocks and other trail hazards
− Sport-focused suspension with newly optimized spring and damping settings is designed for high-performance riding and a high degree of riding comfort with extra passengers
− Wide-body track offers additional stability, especially at speed, yet turning radius remains surprisingly short – just 5.1 meters, the shortest in its class – thanks to the Teryx4’s short, 86.1-inch wheelbase
− Short wheelbase offers other advantages, including a favorable breakover angle, which allows the Teryx4 to climb over obstacles without grounding the undercarriage
− Chassis offers 10.8 inches of ground clearance, an ideal compromise between great low-CG handling and the ability to clear tough off-road obstacles
− Frame design optimizes front and rear suspension’s lower A-arm length for excellent handling performance and minimal geometry change throughout the suspension’s travel
− Chassis and suspension serve up an ideal balance of bump absorption, taut steering and ride comfort with one, two, three or four riders aboard
− The 18 in. x 48 in. cargo bed is both durable and plenty useful, especially with the extra passengers the Teryx4 can easily carry
− Forward-tilting front hood assembly offers aggressive styling and allows quick access to the radiator and front suspension components for easy maintenance and suspension tuning
Sport-focused Suspension
− High-performance fully adjustable gas-charged Kayaba shocks with piggyback reservoirs up front provide excellent fade-resistant damping performance in the toughest conditions while providing 7.75 inches of plush, controlled wheel travel
− Independent rear suspension with fully adjustable piggyback-reservoir shocks provides 8.3 inches of wheel travel and the best possible performance and handling at high speeds
− The piggyback reservoirs on the shocks reduce oil frothing under hard conditions by keeping the shocks cooler under strain
− A rear torsion bar helps minimize body roll, maximizing chassis performance
High-performance Brakes
− Dual front 200mm disc brakes gripped by rigid-mount 27mm twin-piston calipers provide powerful, fade-free braking and solid feel. To protect against damage and debris, the discs are tucked within wheel recesses
− A sealed, oil-bathed multi-plate rear brake system provides maximum stopping power in almost any condition along with reduced maintenance due to its completely sealed design
− The sealed rear brake’s compact design contributes to excellent ground clearance
Large, 26-inch Tires
− 26-inch Maxxis tires developed specifically for the Teryx provide outstanding traction in many different conditions
− Mounted on 12-inch rims, the largest tires available in the RUV category provide outstanding rough terrain performance and obstacle clearance
Handy Cargo Bed
− With a 250-pound capacity and cargo hooks, the 18 in. x 48 in. cargo bed helps carry quite a bit of gear, making the four-person Teryx4 massively functional
Comfortable Cockpit and Ergonomics
− With its massive passenger compartment, the Teryx4 provides plenty of shoulder and legroom
− Form-fitting two-tone bucket seats (the front ones are three-way adjustable) and retractable three-point seatbelts (with an anti-cinch system) help provide a comfortable and secure ride
− Rear seats are mounted higher than those in front, which helps passengers see clearly ahead and makes getting in and out much easier
− Hand holds for front and rear passengers are standard, making it easier to climb in and out of the vehicle
− A drink holder for each seat is standard and helps keep riders comfortable on long rides
− Padded steering wheel is positioned low for comfort and provides additional driver protection
Multi-function Digital Display
− Standard on all models, the Multi-function Display includes a digital speedometer (mph or kph), clock, dual trip meters plus 2WD/4WD/4WD w/differential lock indicator, water temperature and fuel-injection warning indicators, digital fuel gauge, hour meter, parking brake indicator, CVT belt warning, neutral, reverse and low oil pressure warning lights, and much more
Bodywork
− Thermoplastic Olefin bodywork looks great and offers a scratch-resistant surface that’ll look good for a long time
− Standard doors help with getting in and out and also offer a level of mud protection
− Special over-fenders help keep flinging mud at bay, as well
− Standard all-steel front guard helps protect the front of the machine
− Engine and undercarriage guards provide maximum protection from rocks and debris
− Dual 35W headlights and 8/27W dual taillights mean you’ll see and be seen
Range / Transportability
− Large 7.9-gal. (30L) fuel tank and excellent fuel efficiency provide workers, campers, hunters and trail riders the ability to get far, far away and back again
− Even with its wide track and big tires, the Teryx4 is compact enough to fit in the bed of most full-size pickup trucks
2012 Kawasaki Teryx4â„¢ 750 4x4 Specifications*
Engine: Liquid-cooled, 90-degree, four-stroke V-twin
Valve system: SOHC, four valves per cylinder
Displacement: 749cc
Starting system: Electric
Bore x stroke: 85 x 66mm
Compression ratio: 9.3:1
Fuel system: DFI®, 2 x Mikuni 36mm throttle bodies
Ignition: TCBI w/ electronic advance
Transmission: Continuously variable belt-drive transmission with high and low range, plus reverse, and Kawasaki Engine Brake Control
Final drive: Selectable four-wheel drive with Variable Front Differential Control, shaft
Frame: Double-X design using large-diameter, thin-walled, high-tensile tubular steel
Front suspension / wheel travel: Adjustable dual A-arm with gas charged shocks / 7.8 in.
Rear suspension / wheel travel: Adjustable Independent Rear Suspension (IRS) with fully adjustable, gas charged, reservoir shocks / 8.3 in.
Front tires: Maxxis 26x9-12
Rear tires: Maxxis 26x11-12
Front brakes: Dual hydraulic discs with 2-piston calipers
Rear brake: Sealed, oil-bathed, multi-disc
Overall length: 125.2 in.
Overall width: 62.0 in.
Overall height: 77.3 in.
Wheelbase: 86.1 in.
Ground clearance: 10.8 in.
Lighting: (2) 35W headlights, (2) 8 W taillight, 24 W stoplight
Cargo bed capacity: 249 lbs., 47.6 W x 17.9 L x 8.7 in. H
Towing capacity: 1,300 lbs.
Curb weight: 1,616 lbs.
Fuel capacity: 7.9 gal.
Instruments: Multi-function digital meter with speedometer, fuel gauge, clock hour meter, odometer, dual trip meter and parking brake, CVT belt, R/N/P/4WD, water temp and oil pressure indicators
Color: Sunbeam Red, Scout Green
MSRP: $13,399
Warranty: 6 Months
Wholesale distributor: Kawasaki Motors Corp., U.S.A.
*Specifications are subject to change. Media are encouraged to visit KAWASAKIMEDIA.COM for most current specifications.
VIDEOS
2012 TERYX4® COMFORT AND CONVENIENCE
Kawasaki Adventure Hunters
2012 TERYX4® NON-STOP AD SPOT
2012 TERYX4® ENGINE
2012 TERYX4® HANDLING
2012 TERYX4® SOLID CONSTRUCTION
2012 TERYX4® SPACIOUS CABIN
<iframe width="640" height="480" src="http://www.youtube.com/embed/j3YEwEAwFJM" frameborder="0" allowfullscreen></iframe>
I shot this video with my iPhone. It was the first official introduction of the new 2012 Kawasaki Teryx 4.
2012 KAWASAKI TERYX4â„¢ 750 4x4 EPS
Room for Four Plus the Convenience and Control of Electric Power Steering
Separately, Kawasaki’s all-new four-seat Teryx4™ 750 4x4 Rec/Utility vehicle and the renowned Electric Power Steering (EPS) system – which has wowed fans of Kawasaki’s Mule and ATV models – are superb examples of modern technology.
Combined, they are much more than simply the sum of their parts.
Hop into the 2012 Teryx4 750 4x4 EPS’s cockpit, buckle up, hit the starter and mash the accelerator. As you feel yourself pushed into the comfortable high-back bucket seat, you revel in the Teryx4’s ultra-light steering, the sublime control it affords, and the lack of steering kickback as you tackle a rutted trail with three passengers strapped in nearby, each of them grinning like kids with freshly unwrapped popsicles in their hands.
The Teryx4 750 4x4 EPS is a perfect combination of performance and ease of operation: Its additional seats mean you can take extra friends along for the ride (or transport extra help out to the work site). And with the EPS system’s light, low-effort steering, the ride there and back – on fast trails and in tight situations – is exceptionally comfortable and easy.
− Electric Power Steering (EPS) system offers low-effort steering and extra damping at speed and in rough going
− All-new Double-X frame design offers more strength, rigidity and durability for the Teryx4’s extra weight and higher carrying capacity
− All-new bodywork package offers good looks and durability for the long haul, with scratch-resistant material used throughout
− Sport-focused suspension using fully adjustable shocks with piggyback reservoirs front and rear offers an ideal compromise between sporty control and superb ride comfort
− Short wheelbase versus the competition allows a short turning radius (handy in tight situations) and the ability to climb over obstacles that would ground longer and lower vehicles
2012 KAWASAKI TERYX4â„¢ 750 4x4 EPS LE
Features, Comfort and Class: The Industry’s
Most Luxurious RUV Has It All, and More
If your idea of a truly top-of-the-line Rec/Utility vehicle includes luxury and convenience features piled on top of what’s already the most capable, fun and functional RUV in the business, you’d be describing Kawasaki’s 2012 Teryx4™ 750 4x4 EPS LE.
With the Luxury Edition (LE) Teryx4, we’ve outfitted the latest and best RUV in the industry with special features that give it a bit more comfort and cool factor. They include beautifully machined, 12-spoke cast aluminum wheels that are lighter than the steel wheels they replace, and a cab roof/sun top that protects driver and passengers from weather and sun, maximizing the comfort factor and adding a bit of aesthetic appeal in the process.
The Teryx4 LE is a perfect mixture of all that’s good in Teryx/RUV-land: Top-shelf features, the highest possible engine and chassis performance, and a high degree of easy operation. Its additional seats mean you can take extra friends along for the ride (or transport them out to the cabin). And with the Electric Power Steering (EPS) system’s light, low-effort steering, the ride there and back – on fast trails and in tighter situations – is exceptionally comfortable and easy.
Hop into the 2012 Teryx4 750 4x4 EPS LE’s cockpit, buckle up, hit the starter and mash the accelerator. As you feel yourself pushed into the comfortable high-back bucket seat, you revel in the EPS LE’s ultra-light steering, the sublime control it affords, and the lack of steering kickback as you tackle a rutted trail with three passengers strapped in nearby, each of them grinning like kids.
− Electric Power Steering (EPS) system offers low-effort steering and extra stability at speed and in rough going
− All-new bodywork package includes automotive-quality paint finish that offers good looks and extreme durability for the long haul, with scratch-resistant material used throughout
− Lightweight cast aluminum wheels offer great looks and less unsprung weight for improved suspension performance
− A cab roof bolted to the ROPS structure and deflector windshield increase driver and passenger comfort
− Convenience features include standard colored doors, auto-style parking brake, roomy cargo area in back, full instrumentation, dual cup holder, handy hand-holds, two-tone seats, over fenders for mud protection and much more
2012 KAWASAKI TERYX4â„¢ 750 4x4 EPS CAMO
The Industry’s Most Capable Four-Seat RUV, and a Hunting Crew’s Best Friend
There’s little doubt: Kawasaki’s all-new Teryx4 750 4x4 is the best possible vehicle for transporting a group of outdoorsmen – and their gear – to that far-off campsite. Its size, carrying capacity, range, durability and amazing performance make the statement a no-brainer.
But with its radically curvy bodywork smothered with a coating of Realtree® APG™ HD® camouflage, the Teryx4 turns into something else entirely: the world’s pre-eminent hunting-oriented RUV.
It’s true: Kawasaki’s all-new 2012 Teryx4 750 4x4 Realtree APG HD has everything a hunter – and their sportsman friends – could want, especially when it comes to stealth, the unit’s Realtree camouflage accurately mimicking the look of a woodlands area. The camo treatment makes this hunting-oriented Teryx4 blend in like no other RUV in existence, allowing a hunting crew to get where it’s going without attracting attention.
Of course, being built on the Teryx4 EPS platform means the unit also includes all the EPS model’s features, including the amazing Electric Power Steering system that make both slow and fast riding such an easy, confident affair.
Go on… Hop into the Realtree-spec Teryx4 750 4x4 EPS’s cockpit, buckle up, hit the starter and mash the accelerator. As you feel yourself pushed into the comfortable high-back bucket seat, you revel in the Teryx4’s ultra-light steering, the control it affords, and the lack of steering kickback as you tackle a rutted trail with 3 outdoorsman buddies strapped in nearby, each of them grinning like kids.
The Realtree-spec Teryx4 is a perfect combination of performance and ease-of-operation: Its additional seats mean you can take extra buddies along for the hunt (or transport extra help out to the work site). And with the EPS system’s light, low-effort steering, the ride there and back – on fast trails and in tighter situations – is exceptionally comfortable and easy.
− Room for four means twice the personal payload and twice the fun. And with the rear seats mounted higher than those in front, rear-seat passengers have a better view forward – and have easier ingress/egress
− Thoroughly upgraded 749cc V-twin engine offers more power, especially in the low and mid range, exactly where a 4-seat RUV needs it
− Realtree® APGâ„¢ HD® camouflaged bodywork helps make the Camo model the perfect choice for serious sportsmen
− Sport-focused suspension with fully adjustable shocks with piggyback reservoirs front and rear offers an ideal compromise between sporty control and superb ride comfort
− Kawasaki’s expanded Roll-Over Protective Structure (ROPS) helps protect driver and passengers
− Roomy interior offers plenty of room for driver and passengers to stretch out, while ample cargo space means you can take plenty of supplies and gear with you
− Short wheelbase vs. the competition allows a short turning radius (handy in tight situations) and the ability to climb over obstacles that would ground longer and lower vehicles
− Constant Variable Transmission (CVT) and category-first centrifugal clutch offer sporty performance and the slow-speed throttle precision needed in tricky or slow-speed conditions
− Electronic 3-mode 4WD is controlled by a handy cockpit switch and allows instantaneous changes from 2WD to 4WD and 4WD w/differential lock for maximum traction situations
− Convenience features include standard color-matched doors, auto-style parking brake, roomy cargo area in back, full instrumentation, handy hand-holds, dual cup holdrers, over fenders for mud protection and much more
18,569
1,368
113
Re: 2012 Kawasaki Teryx 4 OFFICIAL RELEASE **UTVUnderground Exclusive
Mitch Payton - Manager of Team Monster Kawasaki / Pro Circuit
Me with Villapoto's SX and MX championship trophies from this year!!!
Villapotos bike!
Dean Wilson's bike
Pics of the new Kawasaki ZX-14
More stuff coming today as I cruise around the show!!!!! I will try to do some live posting as well at our facebook page along with video so make sure to head over to UTVUnderground.com - Website - San Marcos, California | Facebook
ROTAX
CannedHam - La Familia
Feb 21, 2011
4,566
185
Pretty cool!! Thanks Joey! But, did I read that right....Curb weight 1616 lbs? Wow, pretty heavy...
mosslager
Nov 4, 2009
1,345
11
Very cool JD!
ROTR
Rock Crawler
Mar 9, 2011
283
Utah
www.rallyontherocks.com
Have they released an availibiity date yet? Hoping if they have pricing established that they will be available right away.
18,569
1,368
113
I will get that info Lanse! Hang tight....working on my laptop during the big presentation going on right now.
AS FYI for you speed freaks, Kawi just introduced a Ninja ZX14R and are showing videos of it SMOKING the Hyabusa!!!! Kawi is coming with it!!
scmo777
Moderator
Jan 20, 2009
489
4
Brawley, CA
Very cool, I think it is going to be a great ride....... good job kawi.
mosslager
Nov 4, 2009
1,345
11
Will the Funco version be an option or all aftermarket
ROTAX
Feb 21, 2011
4,566
185
WOW, I will take the Funco version please!!! (With a turbo, 1616 lbs curb weight, sheeeeesh!!):):)
AZCourt
Feb 11, 2009
525
11
So they put a wet clutch in like Yamaha? The thing that we worked so hard to eliminate in rhino race applications.
hireli3527
