Hmmm...what is this?
Discussion in 'UTV Engines, Performance, Maintenance' started by speedyangie, May 24, 2012.
  1. speedyangie
    speedyangie The Need, The Need For SPEED.......UTVUndergroun d
    Jul 31, 2011
    Cali
    Any help appreciated. Thanks in advance!
    And yes, I do see all the dirt in there. :)
    [​IMG]
    [​IMG]
  2. ROTAX
    ROTAX CannedHam - La Familia
    Feb 21, 2011
    Flux capacitor?
  3. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    Hard to say w/o a wire diagram. I'm guessing diagnostic especially if nothing is affected and no wires are coming out of the piece in your hand and the wires shown are feeders from the ECU. :)
  4. ROTAX
    Feb 21, 2011
    oh yeah,.....my bad:D
  5. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    Reed thats a part Fiche not a wire diagram that id's pins and wires. If you can find one I can read it :D
    typically the plugs have no need for a junction like that, they see 12v (+/-) directly from the ECU so it can control spark and share a common or uncommon ground is how the ECU controls spark by ground depending if they fire together or not.
    The diagnostic port has 6-8 pins and a dirt cap it takes signals from all the ECM sensors, etc, so does the Power Fuse that feeds the relay/fuse block.
    I guess Angie needs to give us some more hints like does it run with all the dirt and disconnected. :D
  6. onerich
    onerich The Carpenter - UTVUnderground's La familia
    Jan 29, 2011
    Elmonte, SOCAL
    I have the shop manual but I need a clue of where it is on the car , also Jay's nails look nice . :D
  7. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    I got my money on Diagnostic, most people find them and go wtf is this lol....we've done it before. If it runs fine with all that dirt thats it and if there is no 12-14 voltage at any pin for sure!
  8. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    Yes, typically it requires dealer software and mating plug to diagnose and/or "flash" reprogram the ECU when it is acting up, for easy access.
    BTW: Not many stock ECUs are programmable but do allow the dealer to make minor changes to AFR for altitude and less restrictive exhaust. Aftermarkets like PC5 have programmable ignition, rev limit, full AFR, etc....
  9. speedyangie
    Jul 31, 2011
    Cali
    So, doing a check on Dev's RZR because his RZR keeps dying. Found two burnt wires already. Cleaned up that piece, doesn't appear to have affected anything from being dirty. :)
  10. speedyangie
    Jul 31, 2011
    Cali
    Also, I've got a manual with the wiring and a manicure. :cool:
  11. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    You could look at ur wire diagram chase the colored wires to that dirty piece, but don't seem like thats the prob. Usually a burnt wire is the result of too much voltage from too low a fuse, or a I call them bad line replaceable units acting like a resistor, etc. Id chased the burnt wires on your diagram to LRU or fuse see wuzz up. Wires should not be sizzling unless they are by heat.
    Thats just a start....:D Dying can be from alot reasons.
  12. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    The regulator/rectifier has a heat sink and cooling fines usually mounted by the ECU/Engine that needs to be clean everyone should check...It can cause over/under voltages to the battery that would throw a code in the ECM. If you have a check engine cluster display your manual should guide u through how to access the code and isolate the issue.
  13. ALBANATE
    ALBANATE Active Member
    Feb 13, 2012
    I'm going resistor module.
    Nate
    Alba Racing
  14. TNT
    TNT Banned Por Vida
    Nov 23, 2011
    So Cal
    Hey look who finally made over to the best site on the net not that RZR.NET kiddie crap! Good calls! Good to see more top notch experience out here. :D
    Bunch of us will be out riding @ ACORN Casino this weekend not far from u come check it out. :rolleyes:
  15. ALBANATE
    Feb 13, 2012
    LOL thanks Terry. Unfortunately I am off to Phoenix for the weekend. And Steve Bielman has my RZR and is prepping it for the next round of LOORS... "The Fastest RZR in the World" is headed back to were it started. LOL
    Nate
    Alba Racing
Share This Page
